Activity Forums Adobe Premiere Pro HELP connecting ANALOG Sony Hi8 mm videocamera to PC and caputure in PRemiere pro
  • HELP connecting ANALOG Sony Hi8 mm videocamera to PC and caputure in PRemiere pro
    Posted by Bart Straman on July 21, 2007 at 8:55 pm
    hi guys
    I realy wanna buy a old school Analog 8mm from sony (pro) that is like 10years old or something. so i need info about capture on pc.
    it has a AUDIO/VIDEO output.
    because this is all new to me
    how do I capture footage shot by this hi 8mm camcorder with PRemiere
    and how do i connect it to my pc
    please help, thanxs
    Bart
    Bart Straman replied 19 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Blast1
    July 21, 2007 at 9:44 pm
    You need a converter of some sort to convert the video from analog to digital and provide the proper interface for the computer, ADStech.com “Pyro A/V link” and canopus.us “ADVC series” or a DV camcorder with passthrough.
  • Bart Straman
    July 22, 2007 at 8:06 am
    heey,
    in that case, pinnacle systems has also a product line that comes alot cheaper. but those product will do the trick at a nice price tag
    on my videocard, i have a composit input. so i think i can put a link between the “video out” of my camera and my pc, only how do i capture the footage then. i don’t think i have any deck control with premiere.. if i link a real big video8 camera to my pc
    any ideas?
    Bart
  • Mike Velte
    July 22, 2007 at 11:09 am
    The Pinnacle boxes and your TV card are just toys and wont work with Premiere. Step up to the $200 ADS Pyro A/V link or buy a used DV camcorder with pass-thru capabilities or go play in a sand box.
  • Bart Straman
    July 22, 2007 at 11:14 am
    let me ignore that last few words of yours,
    second, why won’t they work on premiere? ofcourse, more expensive is better…right but why?
    I have mutiple DV cam’s but how do i know if they can pass through the data?
    thanxs
    Bart
  • Mike Velte
    July 22, 2007 at 1:44 pm
    [Ultimate Bart] “second, why won’t they work on premiere? ofcourse, more expensive is better…right but why?”
    The less expensive hardware captures video as a more highly compressed format like Mpeg 2, which might be fine as you view it, but after editing it will be recompressed again and the results are often poor.
    The other solutions capture as DV (Digital Video) which is about 4X as large as your Mpeg 2 or other proprietary codec.
    Premiere is designed as a DV editor, but with some very expensive hardware ($1K+) can edit most anything above DV.
    q[Ultimate Bart] “I have mutiple DV cam’s but how do i know if they can pass through the data?”
    Plug in any analog source to your DV cam via S/Video or composte, then plug your DV cam into your PC via firewire. Play your analog source. If you can see it on the DV cam’s LCD, you should be able to see it in Premiere’s capture window and capture it. You may have to make a setting in the DV cams menu (analog-in or AV-In)
    Sorry bout the juvenile comment.
  • Blast1
    July 22, 2007 at 6:39 pm
    [mike velte] “You may have to make a setting in the DV cams menu (analog-in or AV-In)”
    To add to Mike’s post, most DV cams in the VCR mode have a menu selection “A/V ->DV Out” On/Off, in the On mode it passes Analog to DV, in the Off mode it passes DV to Analog which can be a help as you can use this to help preview the video you are working on in a external Video Monitor which can give you a better idea of the final product.
  • Bart Straman
    July 22, 2007 at 6:59 pm
    thanxs guys
    those sony hi8 cam’s are realy before my time (1985, and i am 19 myself now) so thanxs for the info. weird there isn’t a “analog camera” forum on this nice website though. but okey. now i can get filming my shots knowing i can get them on my pc, thanxs ^^
    bart
  • Gary Bettan
    July 24, 2007 at 11:47 pm
    The ADS Pyro AV Link is an excellent choice and available now for under $150! The Canopus/ Grass Valley converters are bit more expensive. Boththe ADs Pyro AV Link and the Canopus ADVC converts the old analog signal into DV and sends in into your computer via FireWire. The quality of the video is excellent and Premiere Pro will edit the DV footage with ease.
    For more info https://www.videoguys.com/pyroAVlink.html
    Gary
  • Bart Straman
    July 25, 2007 at 8:20 am
    thanxs 🙂
