Activity › Forums › Maxon Cinema 4D › Help! Can’t move just 2 points on a poly
  • Help! Can’t move just 2 points on a poly
    Posted by Joseph M. morgan on July 19, 2007 at 3:42 pm
    I have a polygon and have extruded some edges, etc (enclosing walls of a ramp). For one edge (really it is just the front edge of a piece), I select the two front points and I want to move them down slightly to create an angled top.
    When I select the points, or the front edge (and I am selecting only visible elements, I’ve quadruple checked), I cannot move those points without moving the entire polygon. That is, even though I clearly have only the edge (or points) selected, everything is moving.
    I also just noticed, too, that in my extrude tool settings, the “preserve groups” checkbox is on… making me think that may have something to do with it. That is, I suspect when I made the extrusion, this checkbox was one (was checking out my settings for anything strange).
    I can, from a blank project, create a cube, make it editable, select two top points and move them down… so it isn’t some wierd setting I have.
    Suggestions?
    Joe
    Joseph M. morgan replied 19 years, 2 months ago 1 Member · 1 Reply
  • Joseph M. morgan
    July 19, 2007 at 7:23 pm
    Don’t ask why or how… but I copied the poly to an empty project, and it started acting normally…. So I edited the object there…. and pasted it back into the bigger project.
    So I must have hit a key combo or clicked on something that got stuff stuck in some kind of way… I don’t know….
    Anyway… if anyone has an idea of what I may have done… please let me know…
    Thanks to whole herd…
