Activity Forums Apple Final Cut Pro Legacy Help… Cant install FCP 4.5 after deleting FCP 5…
  • Help… Cant install FCP 4.5 after deleting FCP 5…
    Posted by Josh Evans on September 28, 2005 at 2:38 pm
    I brought home a project from work which is still on FCP 4.5 . I deleted my FCP 5 and am trying to reinstall 4.5 so it will be compatible with the files from work. but when i try to install i keep getting the message “You cannot continue. There is nothing to install.”
    WTF is going on?
    Josh Evans replied 20 years, 11 months ago 2 Members · 2 Replies
  • Chuck Reti
    September 28, 2005 at 8:43 pm
    You can’t just delete the FCP application. There are many other files that went with it, like Application Support files, Receipts, etc. that are scattered about in various directories. You might consider creating a separate boot drive with other FCP version on it.
    Here is text of a support doc no longer on the apple site, that pertains to uninstalling FCP HD 4.5, but might be of use (at your own risk).
    Final Cut Pro HD (4.5): How to Uninstall
    The Final Cut Pro HD installer does not include an uninstall option. The folders and files installed during a full installation of Final Cut Pro HD are listed below. To uninstall, delete the following items (some items may not be present depending on what has been installed). Note: You may prefer to access these locations via the Finder’s Go to Folder feature (From the Go menu, choose Go to Folder) and enter the Directory name.
    Location
    File/Folder to Delete
    /Applications
    Cinema Tools
    Compressor
    Final Cut Pro HD
    Final Cut Pro HD Additional Easy Presets
    LiveType
    SoundTrack
    /Applications/Utilities
    Batch Monitor (Note 3)
    Soundtrack Loop Utility (Note 2)
    /Documents
    Soundtrack Loops (Note 2)
    /Library/Application Support
    BorisFX
    Boris FX
    Final Cut Pro System Support
    LiveType
    /Library/Application Support/ProApps
    Components
    Final Cut Pro System ID
    /Library/StartupItems
    Qmaster (Note 3)
    /Library/Frameworks
    AECore.framework
    Compressor.framework
    MediaServerAPI.framework
    Qmaster.framework (Note 3)
    /Library/Bundles
    StompTranscoderX.bundle (if present)
    /Library/QuickTime
    FCP Uncompressed 422.component
    DesktopVideoOut.component
    DVCPROHDCodec.component
    DVCPROHDMuxer.component
    DVCPROHDVideoDigitizer.component
    DVCPROHDVideoOutput.component
    DVCPROHDVideoOutputClock.component
    DVCPROHDVideoOutputCodec.component
    LiveType.component
    /Library/Receipts
    Boris.pkg
    CinemaTools.pkg
    CinemaToolsUpdate1.2.pkg
    Compressor.pkg
    CompressorUpdate1.2.pkg (3)
    FinalCutProHD4.5.pkg
    FinalCutProHDUpdate4.5.pkg
    Helium.pkg
    LiveType.pkg
    LiveTypeSupport.pkg
    LiveTypeData1.pkg
    LiveTypeData2.pkg
    LiveTypeUpdate1.2.pkg
    ProAppRuntime.pkg
    ProRuntime.pkg
    ProVideoCodecs.pkg
    Soundtrack.pkg (Note 2)
    SoundtrackUpdate1.2.pkg (Note 2)
    QTProMedia.pkg
    QuickTimeMPEG2.pkg (Note 1)
    QuickTimeProMediaComponent.pkg
    /Library/Audio/Plug-Ins/HAL
    DVCPROHDAudio.plugin
    /System/Library/PrivateFrameworks
    Helium.framework
    LiveType.framework
    ~/Library/Preferences *
    Final Cut Pro User Data
    com.apple.FinalCutPro.plist
    ~/Library/Application Support *
    Compressor
    /System/Library/QuickTime/
    QuickTimeProMedia.component
    * Tip: The tilde “~” refers to your Home directory. For more information see technical document 106167 “Mac OS X: Using Your Home Directory”.
    Notes
    1. Only if QuickTime MPEG 2 wasn’t installed separately.
    2. Only if Soundtrack wasn’t installed separately.
    3. Only if Compressor isn’t installed as part of DVD Studio Pro.
    Article ID: 93811 Date Created: May 04, 2004 Date Modified: June 23, 2004
  • Josh Evans
    September 29, 2005 at 12:07 am
    Thanks so much for taking the time to explain all that. Much appreciated. Has someone released some sort of an uninstall program? WHy didnt apple just include one?
    Cheers
