Help!!! BPAV files not picked up by XDCAM transfer
Okay this is a strange one – I shall describe the steps as they happened. Hopefully somebody can help me.
* Edited a vid sequence in FCP.
* Tried to import more footage from XDCAM Transfer into FCP but got hard disk full notice.
* I moved the source files on to an external hard disk.
* I went to try and reconnect the edited sequence to the source files (all the clip icons in FCP had a red strike through them)
* Final cut crashed on me.
* I wasn’t too annoyed because I planned on starting the sequence from scratch anyway, so dropped the idea of reconnecting. Then took time to take all the source BPAV files and put them in one folder thinking when I re-import all I need to do in point XDCAM Transfer at that one file and then hit ‘Add’ source. (the footage had all be shot at different times so had been pulled of the SXS cards disparately and was in stupidly named files.)
* Problem is here. XDCAM Transfer won’t do it. You select the new main file on the external disk and then click add and a loading progress bar drops down the springs back up and that’s it.
* So not only does my first sequence not work, but I can’t start a new one because I can’t import the original vid files.
Any help would be most welcome!
Notes:
Camera EX1
FCP
