Activity › Forums › Apple Final Cut Pro Legacy › Help! AJA Kona output to hdcam gives nothing but noise and ghosted image.
  • Help! AJA Kona output to hdcam gives nothing but noise and ghosted image.
    Posted by Ikandi Tom on April 18, 2007 at 4:15 pm
    Not sure what to do, any ideas? thanks.
    Tom
    Eric Hansen replied 19 years, 5 months ago 6 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    April 18, 2007 at 4:27 pm
    What format are you working in. Please give way more info. We have no idea what you are trying to do except you have a Kona and an HDCam deck? Format, frame rate of project intended output would help a bit.
    Jeremy
  • Stuart Ferreyra
    April 18, 2007 at 5:18 pm
    Make sure the deck you are using has HD reference /sync.
    If you do not have an external HD reference /sync unit, set up the HD deck (in the deck
    menu) for internal reference.
    Check if the deck loopthough is good goint to your HD monitor. If the loopthrough is
    good and you only get the issues on tape, most likely is a reference / sync issue.
    Good Luck!
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • Ikandi Tom
    April 18, 2007 at 7:19 pm
    Thanks for youe help.
    I have set the deck to int ref sync.
    Getting the same noise through the monitor. makinbg me think it’s not the tape.
    The project was shot on HDV 1080 50, edited on and HD timeline, I’m trying to out put it to 1080 50i (have also tried 25p). Have renderd several versions of timeline. Still no luck.
    Any ideas?
    Cheers from the U.K
  • Jeremy Garchow
    April 18, 2007 at 7:25 pm
    Have you chose the proper easy setup? (Control-q)
  • Ikandi Tom
    April 18, 2007 at 7:38 pm
    Thanks Jeremy,
    Yes I have done, aswell as other options. However there is no 1080 50i option, so I have tried using 1080i/25, . Am I wrongly presuming tius is the same thing? If so how do I export 1080/50i.
    also the Kona control panel Frame buffer always switches to DVCProHD50. Think this may not be helping matters?
  • Ikandi Tom
    April 18, 2007 at 8:40 pm
    Hey, helpful link, but still no joy. ouptu loop looks good, just geen pixelated noise and ghosting when I playback tape.
    I have ref in, but, I’ve now set the servo/av reference on the deck to AUT01, which, according to the manual should switch to an internal reference signal if the OUTREF is not connected,
    still no joy, any more ideas? could it be clogged heads, i heard these thimgs clog up easy?
    Thanks, Tom
  • Tom Brooks
    April 18, 2007 at 9:43 pm
    If you’re trying to output 10-bit through the Kona, try switching output to 8-bit.
  • Ikandi Tom
    April 18, 2007 at 9:52 pm
    Thanks Tom, Using 8-bit. .I kinda have it workin now, I can’t do a digital cut as that seems to cause the problems, now exporting it straight out as playback, luckily this film fest didn’t request clocks and piece kinda fades in. I Managed to manaually get the piece within 4 frames.
    Using 8-bit.
    Thanks, Tom
  • Stuart Ferreyra
    April 18, 2007 at 10:42 pm
    Disable the preview on desktop in FCP.
    I bet that maybe it !!!
    Stuart Ferreyra
    Timecode Multimedia
    President
  • Ikandi Tom
    April 18, 2007 at 11:16 pm
    Just tried that, didn’t fix it, but i see where your headed! cheers.
