Activity Forums Apple Final Cut Pro Legacy Help! AJA Kona output to hdcam gives nothing but noise and ghosted image.
  • Bill Kelly
    April 19, 2007 at 11:57 am
    Regarding the issue with the digital cut, when you’re black and coding the tape, make sure the deck is set to Internal and Preset. When you do the actual Edit To Tape, switch the deck to Internal and Regen. I had that same issue the first time I laid off to an HDCAM deck.
  • Eric Hansen
    April 19, 2007 at 6:22 pm
    I have a Kona LH and Sony M2000/10 HDCAM deck. my deck will not record HD from the Kona using either the external Blackburst Reference (525i signal), or the internal reference settings. the only way is having Kona create the reference for the HD print. in Kona ControlPanel, set the reference to your external blackburst generator (it can be SD, doesnt need to be HD) that is running into the Reference IN on the Kona, then set the deck Reference to Input. this way the deck is receiving an HD reference signal from Kona (thru the video SDI) that is synced to the SD reference from the blackburst.
    thats what works for me and may help your problem.
    e
Page 2 of 2
