Activity Forums Panasonic Cameras help!! 60fps or 30 fps
  • help!! 60fps or 30 fps
    Posted by Zeliha Bozkurt on October 6, 2006 at 3:57 pm
    Hi All
    I am about to start digitizing for a documentary but bit confused about the varicam.
    The tapes are shot at 30 frames per second and at a sytem frequency of 59.94.
    I am digitizing using fire wire- DVCPRO-HD720p 30fps. However not sure if this is the bestodec to goo for. The other codec is DVCPRO-HD720p 60fps.
    The client wants the best possible quality. Which codec should I go for.
    Thank you.
    Zee
    Chris Bell replied 19 years, 11 months ago 2 Members · 1 Reply
  • Chris Bell
    October 7, 2006 at 12:35 am
    If you shot 30p then ingest 30p. No need for the redundant frames.
    Use easy setup DVCPRO HD 720 30p.
    Chris Bell
