Activity › Forums › Maxon Cinema 4D › Help!
  • Björn Marl
    November 9, 2005 at 6:57 pm
    Seems you zoomed out pretty far during working. Just select parallel view from the camera menu of the viewport and then perspective. This will reset your editorcamera to default.
    To avoid this try to use the dolly function instead of zoom.
    Cheers
    Bj
  • Chris Smith
    November 9, 2005 at 8:50 pm
    Your focal length looks like it’s at it’s widest point. Just set it back to what lens you want to use. Make sure you are moving your camera through space and not just changing the Focal length (zooming).
    Chris Smith
    https://www.sugarfilmproduction.com
  • Greg Serafin
    November 10, 2005 at 12:54 am
    in the view, left mouse drag (on the zoom icon) is changing the DISTANCE of the camera, not the zoom.
    right mouse drag changes the actual zoom (as in a zoom lens), you did too much right mouse dragfing and your zoom is set to something stupid like 2mm lens.
    if you are using a camera (which by the looks of the screen shot, you are probably not), then change the zoom in the parameters. if an “editor camera” then simply left drag to get far away from thr objects and then right drag to zoom to it (flatten the perspective)
    iq
  • Norwegian_cow
    November 10, 2005 at 3:13 pm
    Thanks, it works now! 😉
