Help! 1080i to 720p vertical jitters in fcp
I’m working in a 720p (23.967 fps) timeline in FCP and I have to add in some footage is 1080i (shot at 29.97 fps). Also, this 1080i footage is in slow motion, slowed down to 70% in the timeline. When it plays back in the 720p timeline I’m seeing vertical jitters.
I don’t know if it’s an interlacing, frame rate, speed, or codec issue (Sequence compressor is set to DVCPRO HD 720p60) but is there any final cut or after effects solution I can convert the 1080i footage with so I won’t get this jittering problem? Please help!
-Dan
