HELP!! 1080 24p Madness on Final Cut Studio 2
Upgraded to FC Studio 2 per advice given here to be able to deliver 23.98 clips to client shot on HVX 200 @ 1080 24p. Was only able to import @ 1080 60i in FC 5.04. Used Cinema Tools workaround from FC6 and that worked. However…
Now, when I capture the clips in FC6 using log and transfer, it makes them into 29.97, DVCPRO HD 1080 30p, and the Cinema Tools workaround I was using to get the clips back to 23.98 now screws up the aspect ratio of my clips! Also, old workaround left me with 1920×1080 clips while these clips are 1280×1080. Arrrgh!!!
Spent the money to upgrade, and now my problem seems to be worse…
HELP! In the middle of an important job, and must figure this out immediately.
Can’t revert back to FC 5.04 because FC Studio 2 wiped 5.04 out, and I don’t have those disks, hence my purchasing the new software.
