  • Posted by ‘SMR 겜댕 on February 7, 2021 at 8:26 pm
    <pre data-placeholder=”번역”>Hello everybody
    First of all, I am not good at English, so I want to know even if I turn the translator.
    I’m trying to make some expressions, but it’s not working well, so I’m leaving
    When using, activate it with a checkbox
    I want to use an expression that can give the scale value to 100 when the x and y values ​​of the scale are individually adjusted with a slider and unused, so when the checkbox is cleared.
    I don’t know how
    If you can tell me, it will be very helpful.
    Below is the expression I wrote I hope you can tell me the correct answer
    x = thisComp.layer(“Effect”).effect(“Twiggle_Time”)(“slider”);
    y = thisComp.layer(“Effect”).effect(“Twiggle_Value”)(“slider);
    [x ,y]
    if(thisComp.layer(“subtitle”).effect(“checkbox control”)(“check”))true; else
    Dan Ebberts
    replied 5 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 7, 2021 at 9:17 pm
    I’m not sure, but maybe like this:
    if(thisComp.layer("subtitle").effect("Checkbox Control")("Checkbox").value){
    x = thisComp.layer("Effect").effect("Twiggle_Time")("Slider");
    y = thisComp.layer("Effect").effect("Twiggle_Value")("Slider");
    [x ,y];
    }else
    value;
