Activity › Forums › Cinematography › Helicopter Blade / Frame Rate synch? Camera?
Posted by Lazy Nono on December 8, 2011 at 4:01 amHi All,
Any suggestions how I could recreate a shot of a helicopter hovering with its blades virtually unmoving?
https://www.youtube.com/watch?v=M5POy9iKtPA
https://www.youtube.com/watch?v=4vuhn0lRgnUHow would you calculate the necessary frame rate? Take into account number of blades and RPM?
I’m using an HPX-170–would any other cameras be better suited for variable frame rate shooting?Thanks for any help
-Frank
Mark Suszko replied 14 years, 9 months ago 3 Members · 4 Replies -
Todd Terry
December 8, 2011 at 4:20 amShouldn’t be too difficult at all.
I think trying to calculate it by any kind of math would be fairly fruitless… especially considering the rotor RPM will not be predictable, or at all constant. That’s especially evident in the first video, where the rotors appear to move forward a bit, and then backwards. That’s because the rotors aren’t spinning at a perfectly constant rate, but are being varied by either the drag, the throttle variations of the pilot or both.
Firstly, as you probably know you’ll need to shoot at a much higher shutter speed than usual, or the blades will just appear a blur.
Secondly, you’ll need a camera that has a “clearscan” mode. I’m not a HPX-170 user, so I can’t say if it will clearscan or not (I usually shoot with the Canon XLH1, which does). For cameras that will, the clearscan mode allows you do dial in a very precise shutter speed (usually to stop phasing or flickering from HMI or fluorescent lights, or computer screens). In this case though it would be just as easy to use that to “freeze” the rotors. You’d just start with a fairly high shutter speed, and slowly dial the speed up or down until the rotors appear to freeze. You’ll be able to instantly see that in the viewfinder, and shouldn’t take more than a few seconds to land on the right speed.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Mark Suszko
December 8, 2011 at 3:37 pmAdd rolling shutter and props look even MORE trippy and Dali-esque
Todd Terry
December 8, 2011 at 4:03 pmMaybe, not totally sure about that. The blades are moving so fast and the frame rate will have to be soooo high to freeze them that I’m betting a rolling shutter wouldn’t come into play much. Still, I always prefer to shoot with global-shutter cameras anyway, hardly ever with rolling-shutter cameras.
T2
Todd Terry
Creative Director
Mark Suszko
December 8, 2011 at 5:07 pmhttps://www.youtube.com/watch?v=S1oPiyXu-hY
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
