Activity Forums Maxon Cinema 4D Heli blade automation problem
  • Heli blade automation problem
    Posted by Anele Gantyi on February 6, 2014 at 10:37 am
    H, I’m trying to animate the blades of a helicopter. What I want is for the blades to spin up to a certain pace then stay at that pace. How do I do that?
    Anele Gantyi replied 12 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    February 6, 2014 at 5:46 pm
    There’s a number of ways you could approach it:
    1. Use a mograph time effector and animate the strength;
    2. Use Xpresso — feeding a time node into a rangemapper into the prop’s H rotation; or probably the most straightforward method
    3. Animate the H rotation on the first and last frames and then use a time track to control the speed of the rotation.
  • Anele Gantyi
    February 11, 2014 at 12:51 pm
    Im currently using mjr rotator v2 but the problem is that when I rotate the blades, the physical renderer doesnt show blur. But when I keyframe, it shows blur. How do I use time track, where do I access it?
  • Anele Gantyi
    February 11, 2014 at 12:52 pm
    mjr rotator uses expresso
