Hel! the ghost in my machine is starting to get vindictive…
i’m running ppcs6 on a windows 7 x64 pc.
i’ve recently run into some problems with video playback. sometimes the program window i’ve got running on my preview monitor ‘stutters’ ; the image will temporarily freeze, only to resume a few seconds later farther on in the timeline. this ‘stuttering’ happens both in areas with and without rendered previews, and seems to get worse the bigger my projects are. things have recently come to a head in a project i’m working on where playback completely froze up and wouldn’t restart again, no matter how many times i pressed the space bar. i just about jumped out of my seat when it spontaneously started up again about 10 seconds later. there seems to be no problem with the source monitor, and my scopes in the reference monitor stutter at the same points as the image in the program monitor.
other weirdness:
- the playback cursor in the main window will also get ‘stuck’ sometimes when i try to scrub back and forth by holding down one of the arrow keys. it simply won’t move.
- sometimes i will move the playback cursor back to a previous section using the mouse after one of these ‘freezes’ and press the space bar, but playback will start where the cursor was before i moved it back. sometimes the cursor will ‘ignore’ me, repositioning itself back where it was before i grabbed it and moved it.
i read through some of the posts on this forum and came to the conclusion i may have a resource problem, so i took a look at system performance. the whole system w/my project loaded only uses about 8gb of the 32gb memory i’ve got, of which premiere is using about 4gb, so i think i’m ok there. when premiere is playing, the cpu is at only about 20%. there is also actually very little disk activity showing up at all, and no long wait queues. it seems to me my system is far from being overloaded.
so there’s no smoking gun and i’m mystified. is there something i can tweak to make this work, or do i need to look at getting a new system ? and if the latter, does anyone have any hardware recommendations ?
here is my current system :
mobo – asrock z77 extreme6 tb4
cpu – intel i7-3770k 8-core
video – sapphire radeon ultimate 7750 hd
memory – 32gb kingston ddr3
disk1 – 7200rpm seagate 1tb disk for programs, swap, main
disk2 – 7200rpm western digital 2tb disk for videodual-head display — main screen run from sapphire radeon, 2nd screen [for previews] from mobo onboard graphics. [but the same problem occurs when i switch the monitors]
thanks much, ghost busters ! i’m at my wit’s end here…
