Activity Forums Blackmagic Design Heat from MB Extreme
  • Heat from MB Extreme
    Posted by Adam Levine on April 6, 2006 at 1:01 am
    Setting up and testing the new Multibridge today. So far so good, but the unit gets a little hotter than I’d expected. Is this normal? I don’t hear much fan noise. Any guidlines on rack placement for best heat dissipation? Current software and firmware are installed.
    Andrew Mcleod replied 20 years, 5 months ago 2 Members · 1 Reply
  • Andrew Mcleod
    April 6, 2006 at 6:19 am
    Hi
    The construction of MB Extreme is such that the combination of fan for ventilation and case surface area to dissipate the heat is sufficient to keep it running correctly.
    If you boot the MB Extreme into convertor mode you can access the temperature gauge and monitor it this way.
    Installation.
    MB Extremes are robust. Ensure that the ends of the Multibridge Extreme are not covered so that air can pass freely.
    If you have any further questions let me know
    pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
