Heads up on Silicon Image 3726 chips on Multiports
If you’re building your own SATA II Raid and are upgrading to a Sonnet card that supports multiports….make sure you check you Silicon Images 3726 chip’s firmware on your multiports. I’ve been going round and round trying to get the right firmware, finally Silicon Image has posted it on their website. You have to use their Flash program on a PC. That is if you don’t have the 1.0114 firmware.
If you don’t have the right firmware problems include, software identifing the port as a 4726 without RAID, no drives in enclosure, disk utility shows SV-2000 device, performance and reliability problems.
Tim
Tim Langston
Cryin’ Out Loud Productions
Fort Wayne, IN
http://www.colproductions.com
