Activity Forums Boris FX Particle Illusion head moves eyes dont
  • head moves eyes dont
    Posted by Bodybuildingbs on June 24, 2005 at 3:25 am
    Hello
    Am a new user and have a couple of questions.
    1. How do you tell beforehand how many frames the clips has as it is always preset to 120?
    2. Also am using the sparkle in group 2 in places of the eyes in a scene but the actor moved his head so the head moves but the eyes dont/ Whats the simplest track method for it.
    Thank you.
    Aharon Rabinowitz replied 21 years, 3 months ago 4 Members · 3 Replies
  • Elvis Deane
    June 24, 2005 at 5:01 pm
    You can change the default length of the project from 120 frames to whatever you like in the Preferences.
    If you have a compositor that has a tracker, that may be the best way to track the eyes. If not, you’ll have to manually match them up. When doing it manually I find it best first to move the emitter into place every 5 or 10 frames first, and then adding more inbetween keyframes as needed.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Alan Lorence
    June 24, 2005 at 5:09 pm
    If you don’t have a motion tracker, you can always try Smooth Running Gun.
    https://www.3dutils.com/products/srg.htm
    Alan.
    wondertouch
  • Aharon Rabinowitz
    June 24, 2005 at 5:15 pm
    Depends on your Frames per Second. But basically, if your footage is 30 FPS, 10 seconds of video would be 300 frames.
    However, pIllusion can check this for you. In the open footage dialog, on the right side, under the image of your movies first frame, it tells you how many frames it is.
    Also when you import it, in the BG image options dialog, it will tell you what the last frame number is. in addition, if for some reason you still don;t know how many frames it is, just scroll down in the timeline until your footage stops. That’s how many frames it is.
    If you know your FPS, you can set pIllusion to use the same FPS in the project settings. (View > Project settings).
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
