Activity Forums Panasonic Cameras HDX 900 suitable shutter speed?
  • HDX 900 suitable shutter speed?
    Posted by Simon Cox on August 23, 2009 at 6:10 pm
    In a couple of days I’ll be shooting with a HDX 900 in 1080-50i, 25P for broadcast in the UK.
    I’m slightly confused by the ‘System Mode’ & ‘Camera Mode’ settings within the ‘System Settings’ of the Main menu.
    I’ve set the ‘System Mode’ to 1080-50i and the ‘Camera Mode’ to 25P. Is the 50i referring to ‘Interlaced’? By switching the ‘Camera Mode’ to 25P I presume I’m shooting in Progressive.
    How does this affect the shutter? should it be off or set to a ‘Half’?
    I’m more used to cameras where I set to progressive and then switch the shutter to a 50th.
    Any advice appreciated. Subject matter by the way is people climbing trees in a forest so no high speed required.
    Robin Probyn replied 17 years ago 3 Members · 8 Replies
  • 8 Replies
  • Ernie Santella
    August 24, 2009 at 3:01 pm
    In 1080 mode, the camera will actually record interlaced. The 25p is framerate. What happens is, the camera records to tape at 1080/50i and adds the 25fps pull-down automatically. And yes, set the shutter to ‘half’ to get an accurate film/shutter look.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Robin Probyn
    August 25, 2009 at 5:14 am
    Yes a bit confusing when you first use HDX or Varicam..
    The half shutter means its giving you a 180 degree shutter angle for what ever you have set the camera for… ie a half.. so at 25p half shutter is 1/50th.. just saves you having to work it out yourself.As far as i know anyway !!
    And in theory replicating a film camera.. sometimes I,ll switch it off if I need a bit more stop.. as long as not alot of action in the scene its fine..
  • Ernie Santella
    August 25, 2009 at 5:49 am
    I 2nd that. I switch it off once in a while too for the extra stop.
    Ernie Santella
  • Robin Probyn
    August 25, 2009 at 5:52 am
    Something that cant be done on a film camera!
    Ive being setting the gamma to .55 a fair bit these days.. do you phutz with gamma much?
  • Simon Cox
    August 26, 2009 at 9:52 am
    Many thanks,
    That confirmed what I thought. Did the shoot yesterday and all seemed to go well.
    Ta for the help.
    Simon
  • Robin Probyn
    August 27, 2009 at 1:21 pm
    Glad it went well… HDX900 is a good swissarmy knife camera.. good for freelancers.. and way cheaper than F900R… you can also shoot slo-mo in 720p mode ie shoot at 50p for 25p
  • Simon Cox
    August 28, 2009 at 4:24 pm
    I quite liked the camera but the viewfinder is not my favourite. Mind you I’m not keen on the one on the 750 /790 always seems a tadge milky to me. Might be that the Hire Company have put on a cheaper one but I doubt it.
    Hopefully I’ll get chance to try the 720p slo mo at some stage.
  • Robin Probyn
    August 28, 2009 at 10:45 pm
    Yes totally agree about the viewfinder… one drawback..
