Activity Forums Apple Final Cut Pro Legacy HDV works – but HDV from AE does not
  • HDV works – but HDV from AE does not
    Posted by Bob Cole on October 27, 2008 at 7:10 pm
    Helping out a friend who wanted to learn how to do something in After Effects, I came across a situation that I’ve never seen.
    I’ve avoided editing in HDV within FCP – always transcoded to DVCPro or even DV. But my friend wants to edit HDV.
    His HDV camera shots play just fine, but when I made an HDV file in After Effects, it played back very jerkily in FCP. In AE I’m using the standard HDV render setting. The properties (data rates, fields, pixel dimensions) for both his camera originals and my AE HDV files seem quite similar, but the performance isn’t.
    Is there some special trick when rendering in the HDV codec in AE for FCP?
    Bob Cole
    Bob Cole replied 17 years, 11 months ago 3 Members · 4 Replies
  • Bob Cole
    October 28, 2008 at 3:12 am
    [Dave LaRonde] “Sorry to say this, but yes, there is a special trick: don’t do it.
    Although the Adobe propaganda leads one to believe that AE supports HDV, it really doesn’t.”
    My friend is adamant about using HDV in FCP. My work-around: render out of AE in HDV or DVCProHD, import to FCP, render again to make it playable, export a QT HDV movie. The end result plays fine.
    btw — he’s using a laptop – does he have any alternatives for an editing codec? He has no auxiliary input device.
    I have a MacBook Pro with a Kona LHe, so I have managed to avoid HDV as an editing codec, which makes me unable to advise him.
    Bob
  • David Roth weiss
    October 28, 2008 at 3:22 am
    [Bob Cole] “btw — he’s using a laptop – does he have any alternatives for an editing codec? He has no auxiliary input device.”
    ProRes is the answer Bob.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Chris Poisson
    October 28, 2008 at 3:32 pm
    Bob,
    If your friend thinks there’s an advantage, ANY advantage, to do any kind of manipulation with the HDV codec, then I have a bridge to sell him. He’s off his rocker or exceedingly ill-informed.
    As David says, ProRes.
    Have a wonderful day.
  • Bob Cole
    October 28, 2008 at 4:27 pm
    I’m not arguing with you about editing HDV; I told him the same thing. I appreciate the advice on how to deal with someone who has already done all his captures and has to deal with HDV. I’ll let him know that he should use ProRes in the future.
    bob
