Activity Forums Apple Final Cut Pro Legacy HDV to SD via Apple Pro Res
  • HDV to SD via Apple Pro Res
    Posted by Ellen Zweig on August 7, 2010 at 3:48 am
    I’m editing in HDV (using FCP6)and trying to get a good quality SD DVD (yes, I know this is difficult)…so, I made an Apple Pro Res (1440 x 1080)HQ sequence and copied my HDV edited video into that. Then, I exported using Quick Time Movie set for 1440 x 1080. The Quick Time Movie is pillar boxed. My HDV edited video is 16:9. But the QT is squishing it to 4:3. When I then take this into Compressor, it still looks pillar boxed. Am I doing something wrong? Any advice would be much appreciated. Thanks, Ellen
    Mikey Bouchereau replied 16 years, 1 month ago 2 Members · 1 Reply
  • Mikey Bouchereau
    August 8, 2010 at 3:33 am
    It sounds like your aspect for the footage and the sequence are off.
    I would take a clip from your browser add it to your timeline – it should show up as 16×9 with no Pillar Box. Double click on that clip look at the distort settings, then check those against your other clips. If there is a difference, select all the distorted clips and choose remove attributes (distort), then copy the good clip and choose paste attributes (distort) and it should be all set.
    Mikey B!
    Follow Me On Twitter!
    Check Out My Sky Replace Tutorial
