Activity › Forums › Apple Final Cut Pro Legacy › HDV to DVCPROHD
  • HDV to DVCPROHD
    Posted by Brian Paterson on October 30, 2009 at 2:30 pm
    HI I was reading the interesting article by Gerry Hofman on working with HDV in FCP and am interested in trying the HDV to DVCPROHD method of cutting down on the rendering time. He says this conversion can be done in compressor 2. As I have never made any use of compressor but have dabbled with it unsuccessfully a couple of times and subsequently fought shy of it, is there some advice I can get about how to set up this conversion process. Also I didn’t quite understand his phraseoligly when he said “The downside to this is the “double duty” spent in software compression after capture, as well as consuming more disk space.” What does he mean by ” the software compression after capture”? Also how much more disc space are we talking about.
    Many Thanks
    brian paterson
    Jeff York replied 16 years, 11 months ago 4 Members · 4 Replies
  • Walter Biscardi
    October 30, 2009 at 3:44 pm
    [brian paterson] “What does he mean by ” the software compression after capture”? Also how much more disc space are we talking about. “
    Meaning you capture your footage to HDV. Then you send all that footage through Compressor to convert to DVCPro HD after the capture and the resulting render time involved.
    This is precisely one of the reasons why we run the AJA Kona boards here. They convert footage to whatever format we want it to be in realtime during ingest. No after capture rendering to do.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Brian Paterson
    October 30, 2009 at 4:07 pm
    Many Thanks Walter,
    I checked out the AJA kona boards here but at One thousand pounds starting price that’s way over my budget right now. I understand now about sending the footage through compressor but tell me would the quality be any less through compressor than it would be if I did buy an AJA Kona board. – By the way “export to compressor” always seem to be greyed out when I look at it. Can I just drag the capture files to compressor to do this.
    Regards
    brian paterson
  • David Roth weiss
    October 30, 2009 at 7:05 pm
    [brian paterson] “I was reading the interesting article by Gerry Hofman on working with HDV in FCP and am interested in trying the HDV to DVCPROHD method of cutting down on the rendering time.”
    Keep in mind that Jerry’s article is out of date now and transcoding to DVCPro is no longer in fashion. Pro Res is a much better codec for this purpose. It’s 10-bit vs 8-bit for starters, and there’s much less temporal information lost during the transcoding process.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jeff York
    November 7, 2009 at 7:45 am
    To echo what David said, you’re going to want to get your footage into the appropriate ProRes codec for editing.
    Before loading anything into Final Cut, take all of your digitized files, drag them into Compressor, attach the appropriate setting and destination, and “submit” the job.
    Going the AJA route is great because you can do things in realtime instead of having to wait for Compressor to do its job, but the end quality result should be the same. Your footage has already been kissed by the HDV codec. It’s not going to get worse.
    In my travels, I’m always surprised to hear people who haven’t embraced Compressor as a core part of their workflow. It’s the right tool for many jobs. Especially cool with Compressor 3.5 is how easy making droplets for your desktop are. How many times does a client send you audio in MP3 format? I have an MP3 to AIFF droplet on my desktop. Poof, in seconds I have a useable file.
    You know everything you had wished Quicktime Pro did? Compressor does it…and more.
