Activity › Forums › Avid Media Composer › HDV to Avid via Final Cut
  • HDV to Avid via Final Cut
    Posted by Michael Brown on May 4, 2009 at 3:46 pm
    Running MC Adrenaline 3.1.1
    I have about 3.5 hours of HDV footage that was captured to QuickTime using Final Cut. Avid does not recognize the format. Is there any way these can be brought into the Avid or is it time to rent a deck and capture again? Thanks for any advice.
    Mike Brown
    Video/Film Producer
    American Heart Association
    Michael Brown replied 17 years, 5 months ago 3 Members · 3 Replies
  • Brian Moss
    May 4, 2009 at 6:13 pm
    Quicktime is just a wrapper of the footage. The question is if you have the right codec installed on your avid. What was the compression that Final Cut used and is that codec on your avid machine. If not you will need it installed. If you not sure hit Ctrl+I for a pc and it will you give you info of the clip. Hope this helps any questions please leave more info about the clip.
  • Shane Ross
    May 4, 2009 at 9:00 pm
    The HDV codec that FCP uses is only available with FCP. You must install FCP to get this codec.
    The other party will have to get the Avid codecs and transcode to one of them, or to something like Photo JPEG 100% or 75%.
    Shane
  • Michael Brown
    May 5, 2009 at 1:06 pm
    Thanks, Shane. I thought this was the case, but I was hoping otherwise.
    Mike Brown
    Video/Film Producer
