Activity › Forums › AJA Video Systems › HDV to 1080 using the Kona LH
  • HDV to 1080 using the Kona LH
    Posted by Jhaughey on August 9, 2006 at 9:19 am
    hello,
    has anybody successfully done this?
    I’m using all the most up to date equipment…
    I’ve set up everything as I think it should,
    however when it captures, the frame size is half what it should be, i.e 960×540….
    Also on the kona control panel, everything looks fine (its getting a 1080 compnent signal and analog audio,
    however, there is a thin red line around the analog in icon… anyone have the same issues?
    I’m using the Sony M10 deck. its all in PAL.
    would any of you kind contributors care to set me straight on what the settings should be?
    thanks,
    Joe
    Jhaughey replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
