HDV Rendering Solutions
I am getting ready to edit my first long format work in HDV and I was wondering if there was any miracle worker out there that would cut down on render time.
The system did not come with a Blackmagic Card, but we are in the process of purchasing one. Will that have any effect in terms of render time?
I know that you can capture your footage in SD and then convert only what you need to HD and that is probably what I will end up doing, but I was wondering if anyoen knew of any other solutions.
Ryan
