Activity › Forums › Apple Final Cut Pro Legacy › HDV: Raid / 8xAGP. What’s first?
  • HDV: Raid / 8xAGP. What’s first?
    Posted by Francois Driessen on September 19, 2005 at 5:45 pm
    Hi there.
    Anyone in the heard know what would be the first thing to do to get the rendering faster for HDV in FCP on a d2 G5:
    Upgrading to 8x AGP like the Nvida 6800 Ultra since we’re dealing with long GOP?
    of Going to SATA Raid drives over internal second SATA drive?
    thnx.
    Francois
    >- e y e f l a m e .tv –< https://eyeflame.tv
    Graeme Nattress replied 21 years ago 3 Members · 3 Replies
  • Graeme Nattress
    September 19, 2005 at 5:54 pm
    Other than a faster processor, nothing much will help. FCP processing is not GPU based, so a better GPU won’t help unless you’re doing tonnes of motion work, and I’d get the ATI anyway as you won’t waste a slot.
    A big raid will help a little, but as native HDV has small file sizes, that’s not your bottle neck.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Kevin Monahan
    September 19, 2005 at 9:15 pm
    Isn’t it odd that the data rate is lower than DV, yet it takes longer to render out? Is that because of the frame size? Or is it just the encoding process? Both? Wondering.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Graeme Nattress
    September 19, 2005 at 9:21 pm
    Larger frame size, more complex codec. It all adds up….
    Graeme
