Activity › Forums › Apple Final Cut Pro Legacy › HDV-ProRez_for CC
  • HDV-ProRez_for CC
    Posted by Jim on July 16, 2008 at 10:35 pm
    I know that the HDV Pro Rez has been discussed many times. But I have one more slant on the question and would humbly appreciate your collective wisdom.
    I have 4 hrs of HDV (digitized) I will need to do some serious color/level correction, and was thinking that ProRez might really be my best choice. When I look in compressor for the ProRez Codec it gives me a choice of ProRez (1440) and ProRez (HQ) 1900.
    So…If I want to transcode to ProRez… 8 bit HD(1440) or 10 bit HQ(1900)? Also, would I be best off using compressor, MM or perhaps Episode (or other)?
    In addition, I have noticed that when I go to the color correction window, on a still frame, my levels appear to be clamped at 100% (Kona 3, FCS2 6.0.4, QT 7.5, PowerMac Quad), but when I hit play I see my histogram & WF shoot up into the red + 100 range (I’ve only seen this happen with HDV).
    Any insights would be greatly appreciated?
    Cheers,
    Gary Adcock replied 18 years, 2 months ago 2 Members · 1 Reply
  • Gary Adcock
    July 17, 2008 at 10:51 am
    [Jim Cunningham] “So…If I want to transcode to ProRez… 8 bit HD(1440) or 10 bit HQ(1900)? Also, would I be best off using compressor, MM or perhaps Episode (or other)? “
    Hey jim
    stick to the standard version, less hassles on playback-DO NOT use MM if you have or need content going into AE or Shake, as MM will not process the footage @ full raster.
    I like and use Episode with great results.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
