Activity Forums Apple Final Cut Pro Legacy HDV PROCESSING TIME with quadcore
  • HDV PROCESSING TIME with quadcore
    Posted by Alvaro Lanciai on November 22, 2007 at 7:04 pm
    hi there,
    I’ve a big trouble with fcp…my computer takes 24 hours to process one hour HDV project to m2v format “exporting with compressor” – 90 min fastest encode – PRESET directly from fcp.
    ….duration is the same making a .mov file (current settings) and encoding in a second time with compressor using the same preset.
    I heard from somebody that the quadcore has a bug encoding hdv materials….
    …anybody could help me…?
    thank you in advance
    MAC INTEL dual quadcore 3ghz
    4gb ram
    macos 10.4.11
    fcp 6.0.1
    Chris Poisson replied 18 years, 9 months ago 3 Members · 2 Replies
  • Chris Borjis
    November 22, 2007 at 8:38 pm
    I have not had that problem.
    Unless your conforming HDV to go back to HDV Tape.
    That takes a very long time.
    Have you tried exporting the sequence as a quicktime then encoding that with compressor?
    That will cut down the compressor render big time.
  • Chris Poisson
    November 22, 2007 at 9:35 pm
    Unless you’re going back to HDV, why work in HDV? Rendering native Firewire HDV to say 8 bit or ProRes takes nowhere near the time it takes to conform.
    And yes, export a movie for Compressor. Going from FCP to Compressor can take many times as long as using a QT movie.
