Activity › Forums › AJA Video Systems › HDV Playback on SD Monitor
  • HDV Playback on SD Monitor
    Posted by Marc Thomas on February 17, 2006 at 4:49 pm
    Hey all,
    An editor working with us is cutting HDV in FCP, and not able to playback real-time on a SD monitor. I thought that the Kona LHE’s down converted to SD for monitor out. Is that not the case? Or is there some kind of hinky thing that happens with HDV?
    Any help appreciated.
    Cheers,
    Marc
    Oliver Peters replied 20 years, 7 months ago 6 Members · 6 Replies
  • Wayne Carey
    February 17, 2006 at 5:17 pm
    HDV is a whole different creature in FCP, but I seem to have the same problem as you. Until this is solved, I monitor the signal from the HDV using the S-Video Out to my production monitor – this only works when you capture the footage. According to AJA, I should be able to monitor HDV using my Kona2 but that hasn’t happened just yet. I get the same results as you.
    _____________________________
    Wayne Carey
    wcarey@strikeking.com
  • John Ladle
    February 17, 2006 at 6:19 pm
    you probably want to give AJA a call and get it rolling. the kona 2 and LH/LHE cards can definitely do realtime downconvert…it happens on the board, so likely there is a wrong setting or something. what does your control panel say?
  • Wayne Carey
    February 17, 2006 at 8:53 pm
    From uncompressed:
    < the kona 2 and LH/LHE cards can definitely do realtime downconvert...it happens on the board, so likely there is a wrong setting or something. what < does your control panel say? Well, my control panel says its outputting 525i29.97, which is my primary output since I broadcast in SD video. Therefore, my analog output (which I use for my broadcast monitor) is my primary output. Is that wrong? And what are the settings you are using? _____________________________ Wayne Carey wcarey@strikeking.com
  • Jeremy Garchow
    February 17, 2006 at 9:41 pm
    Your primary format should be whatever format you are working in (Which sounds like HDV 1080i?). Then you set your secondary format as 525i29.97 and then select the analog output and change it from primary to secondary.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Kevin Wild
    February 18, 2006 at 8:27 am
    I take everything in via DVCProHD, but the downconvert works perfectly for me. Matter of fact, I love it. It’s so awesome to have realtime output to my SD monitor with a choice of letterbox, centercut or anamorphic, all while I’m watching the HD version right above it on my Dell monitor.
    What a great setup the Kona LHe is…
    Hope you get it working with HDV…
    KW
  • Oliver Peters
    February 19, 2006 at 1:00 am
    At least on the Kona2 you can definitely play HDV in real-time. I’ve seen it in HD, but I haven’t checked the SD downconversion. These are separate functions though, so it should work. Make sure you are in an HDV sequence though and don’t have a timeline with mixed media. In an all-HDV timeline, the sequence plays in real-time without any rendering/conforming needed. If you ask FCP to render – it will do a conform, but this isn’t needed for Kona2 output in real-time. If you have a mixed-format/codec timeline, then the HDV will have to be rendered first.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
