Activity › Forums › Apple Final Cut Pro Legacy › HDV pal to Ntsc for edit
  • HDV pal to Ntsc for edit
    Posted by Paul Gregory on May 22, 2011 at 10:44 am
    Hi all this is my first post although I have used and leaned a lot from CC before.
    I need some advice on a project I have been asked to do. I am capturing footage on a Sony FX7 in HDV pal and I need to send the clips to the USA for editing I am using final cut pro and am asking what the best file format to send. I think the final edit will be for the web but it may be outputed to DVD as well.
    Paul
    Chris Tompkins replied 15 years, 4 months ago 2 Members · 5 Replies
  • Chris Tompkins
    May 22, 2011 at 4:07 pm
    What do the folks in the USA want?
    Chris Tompkins
    Video Atlanta LLC
  • Paul Gregory
    May 22, 2011 at 5:26 pm
    Thank you for your reply Chris. Well I have not had conformation as to what they want exactly but Im assuming a mov file of some sort but what codec Im not sure Im just trying to get some surgestions.
  • Chris Tompkins
    May 22, 2011 at 6:15 pm
    You can convert with compressor with marginal results.
    Nattress has a pug-in that I read good things about.
    Maybe include the PAL clips with the new NTSC clips as another option for the receivers.
    Chris Tompkins
    Video Atlanta LLC
  • Paul Gregory
    May 23, 2011 at 7:10 pm
    Thank you for your reply Chris I will look into Nattress can you tell me the best way to inport and send the raw files from the camera.
  • Chris Tompkins
    May 23, 2011 at 9:19 pm
    You capture the footage off the camera via FW.
    Chris Tompkins
    Video Atlanta LLC
