Activity Forums Apple Final Cut Pro Legacy HDV multiclip editing
  • HDV multiclip editing
    Posted by Brian Pitt on May 20, 2008 at 5:50 pm
    I had a shoot yesterday that was shot with 2 Sony HDV cameras. The camera’s time code was synced up because I had planned on doing multiclip editing.
    I created a multi-clip sequence using my two clips, but It will not play back in real time without a render!
    Can you not do multiclip editing with HDV footage? can anyone help me out here?
    Brian
    Brian Pitt replied 18 years, 4 months ago 3 Members · 3 Replies
  • Tim Vaughan
    May 20, 2008 at 6:00 pm
    I have personally edited quite a few HDV clips with very little problem. I did have this same exact scenario last week, but it was with a different format. The problem, as it turned out, was the sequence frame rate was different from the footage frame rate. Maybe give that a quick check?
    Hope this helps
    Tim
    Tim
  • Joseph Moore
    May 20, 2008 at 7:58 pm
    I’m almost done with my first multiclip job, a four camera edit, but I converted the HDV to ProRes on capture. I was pleasantly surprised that every worked as advertised.
  • Brian Pitt
    May 20, 2008 at 9:08 pm
    Tim,
    That was what exactly the problem. I switched the sequence settings to 1080i60 and it worked perfectly. Thanks!!!
    Brian
