Activity Forums Apple Final Cut Pro Legacy HDV-M25U and FCP
  • HDV-M25U and FCP
    Posted by Terry Ballard on April 13, 2010 at 9:23 pm
    Can anyone help… I’m using FCP and SONY’s HDV-M25u HDV deck. The deck is connect via firewire I have a plasma that I want to see my finished project on. I want to play my timeline, pass through the deck via HDMI and see in on the plasma. What are the deck settings/project setting?
    Any and all info is appreciated.
    Terry B
    Andy Mees replied 16 years, 5 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    April 14, 2010 at 1:48 am
    [Terry Ballard] “What are the deck settings/project setting?”
    There are none. The only way to play HDV out is with a capture card.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Andy Mees
    April 14, 2010 at 6:23 am
    Set you Video Playback to “Apple Firewire” (PAL or NTSC as appropriate) and this will send your HDV timeline to your M25 deck as a letterboxed SD DV signal (via a realtime software downconvert courtesy of FCP’s RT Extreme playback engine) … you should be able to watch that on your plasma via the deck, but it’ll be pretty crap I’m afraid.
    Best
    Andy
