Activity › Forums › Apple Final Cut Pro Legacy › hdv m10u deck not recognized anymore
Posted by Tom Penna on April 2, 2010 at 9:37 pmI have a Sony M-10U HDV Deck. Final Cut Pro v. 5.1.4 and a G5 v. 10.4.11, Dual 2 Ghz wt. 4 GB DDR SDRAM
I have used this setup for years and then all of a sudden it just stopped recognizing the deck. The deck turns on and is fine. I have tried multiple input formats and Final Cut will not recognize it.
Suggestions?
bwp
David Roth weiss replied 16 years, 5 months ago 3 Members · 6 Replies -
David Roth weiss
April 2, 2010 at 10:02 pmTrash preferences and fix permissions.
Pull the plug out of the wall on the deck, then plug it in again.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
David Roth weiss
April 2, 2010 at 11:26 pmTom,
Please search “permissions” using the forum search function. It’s asked and answered nearly every day, and every FCP editor must know how to do it. You will remember it if you find the answer yourself.
David Roth Weiss
Tom Penna
April 3, 2010 at 12:16 amThanks, I did search the forums and didn’t see anything that matched up with what i need to know. My computer is not recognizing the deck in the firewire connections tab. I repaired permissions on my Mac HD, but couldn’t do it on my Lacie Externals. I don’t mind researching at all, but if you could possibly email me the link I would appreciate it.
Thanks Again
bwp
Andrew Kimery
April 3, 2010 at 12:28 amIf the Mac itself isn’t seeing the deck it’s most likely a hardware problem. Either the FW port on your deck is bad, the FW port on your Mac you are trying to use is bad or the FW cable you are trying to use is bad.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1) -
David Roth weiss
April 3, 2010 at 1:59 amDownload Preference Manager from https://www.digitalrebellion.com and use it to trash your preferences.
David Roth Weiss
