Activity › Forums › Apple Final Cut Pro Legacy › HDV into FCP capturing a tape without ‘scene’ breaks
  • HDV into FCP capturing a tape without ‘scene’ breaks
    Posted by Robin on August 11, 2005 at 12:22 pm
    Ok I’ve figured out what is going on here.
    When capturing HDV into FCP you have a choice of how FCP reacts to where the camera has been switched off and on again.
    It will either stop capturing or it will split up the clips when it sees a break. This is actually really annoying for me!
    I just want to capture the whole tape as one clip and then decide where I want to split my clips.
    I’ve seen a piece of software called lumiere hd, but have no idea if this will solve the problem (let me capture as one big clip)
    Any ideas?
    Matt Jeppsen replied 21 years, 1 month ago 4 Members · 13 Replies
  • 13 Replies
  • Walter Biscardi
    August 11, 2005 at 12:28 pm
    You can tell FCP to ignore timecode breaks and it will simply give you a warning at the end of the capture that timecode breaks are present.
    Keep in mind however that your timecode will not be accurate for any clips after the first TC break. So you will not be able to go back and recapture just one clip accurately in the future.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Robin
    August 11, 2005 at 12:44 pm
    FCP will not do this with HDV at the moment, I refer you to the following article:
    https://docs.info.apple.com/article.html?artnum=301715
    This is the key line:
    Warn After Capture
    When you capture HDV, this option behaves identically to the Abort Capture option.
    And there lies my problem
  • Steve Connor
    August 11, 2005 at 12:48 pm
    Try this:
    When capturing HDV footage from a Sony HDV camcorder using Final Cut Pro 5.0.2,
    you can choose how Final Cut Pro creates media files and clips when start and stop
    indicators are detected. (Start/stop indicators occur on a tape in places where
    recording was stopped and then started again.)
    To choose how Final Cut Pro handles start/stop detection when capturing
    HDV footage:
    If you have not already done so, choose Final Cut Pro > Easy Setup, then select an HDV
    Easy Setup from the
  • Walter Biscardi
    August 11, 2005 at 12:51 pm
    [Robin] ”
    Warn After Capture
    And there lies my problem”
    Ah, as I haven’t worked with HDV footage to date, I have not experienced that. All of my work has been DVCPro HD and HDCAM.
    I’m betting that limitation has something to do with how the footage is recorded on the HDV tape.
  • Walter Biscardi
    August 11, 2005 at 12:52 pm
    [Steve Connor] ”
    (from FCP late breaking news via the help menu!)”
    Wow, you actually read those things? I guess we all should. 🙂
  • Robin
    August 11, 2005 at 12:54 pm
    It’s to do with the fact that HDV works with Mpeg2 GOP files or something.
    I’m trying something new now…
    I’ll give you feedback if it works to save someone going through my last 24 hours experience.
    Robin
  • Robin
    August 11, 2005 at 12:57 pm
    Man you are doing so much to help me out, I really appreciate it. So cool of you.
    Funny we must be on the same page. I just found the exact same page from the Apple site. I’m trying it out with the two settings-
    One in Clip settings (checkbox off)
    and also the setting in user preferences.
    Hopefully the combination of these two settings will fix the problem.
    I’ll let you know in about 15 minutes…
  • Steve Connor
    August 11, 2005 at 12:59 pm
    Beauty of the COW man….. you’re never alone!
    Steve Connor
    Cardinal HD
  • Robin
    August 11, 2005 at 1:03 pm
    where it kept stopping, so it looks like we’ve solved the case!!!
    13 minutes continuous capture so far….
    Woo Hoo!
  • Robin
    August 11, 2005 at 1:04 pm
    nm
