Activity › Forums › Adobe After Effects › HDV Greenscreen Workflow help, please
  • HDV Greenscreen Workflow help, please
    Posted by Alan Tailer on October 24, 2007 at 7:10 pm
    I just got an HDV camera and shot several takes against a Green Screen to create a simple music video. Several questions about workflow:
    1) Is After Effects the best choice to create a video like this from scratch: https://www.youtube.com/watch?v=WpB6_sTl7aI or is something like Vegas Video better?
    2) As far as work-flow, should I Chroma-Key each video-take and save each as 720×480 transparent background videos to start combining them in the final project (to keep individual file sizes from getting too large to deal with)? Or keep the individual video sizes at 1920×1080 until the final rendering?
    I’m running WinXP 2.8 CPU w/2BG ram and woefully uneducated on working with HDV and related software programs to get bet results. Any feedback is appreciated, thanks!
    PS – That Youtube video example I showed is way, WAY better than anything I’d hope to achieve, but I DID want to use multiple greenscreen video-takes to move in/out of the video like that in a much simpler way.
    Alan Tailer replied 18 years, 11 months ago 4 Members · 5 Replies
  • Alan Tailer
    October 24, 2007 at 11:02 pm
    Thanks for the detailed response, Dave…
    Actually, I’m just trying to create more pro-looking videos to put online, I thought shooting in HDV would be an improvement, that having a larger-pixel capture would improve the final result even if the final video was 360×240 (or am I wrong about that?)… Or is it more about how the video’s processed AFTER shooting?
    I’m not even after the “wide-screen” look, just trying to create some low-budget music videos to put online that don’t look really amateurish. I’m going to have to compare my old DV camera to the HDV I just got to see if it justifies the huge extra hassle I’m having working with the HDV output. Thanks again for your comments, I’ve got a big learning curve ahead of me.
    Edit: I guess this is off-topic, but here’s a video claiming to show the difference between DV and HDV:
    https://youtube.com/watch?v=_GIiU7YQAHc
    …Is that legit? (HDV is automatically better even when rendered to 320×240 versus DV), or does that say more about the quality of the camera lense of that specific HDV recorder?
  • Kevin Camp
    October 25, 2007 at 2:04 am
    shooting hdv and down-rezing should look better than down-rezing dv. the down-rezing will help to reduce the noticeable artifacting of the dv codec, the more you down-rez the less noticeable the artifacts….
    the question is, is it worth the extra hassle? i don’t know…
    another way to improve quality is in the final compression. i’ve never posted to youtube, but i’m sure i’ve read some recommendations here at the cow for compressing for youtube. i remember something about if you use their native codec/compression settings you can avoid youtube recompressing your media and get better looking videos.
    try searching the ae archives for ‘you tube compression’.
    back to hdv… you might want to consider exporting or even capturing your hdv to photojpeg at best (or 100%) quality. ae works very well with photojpeg, and the file size will be significantly smaller than uncompressed or lossless compression. photojpeg should be an export option using quicktime from most nle’s.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Richard Harrington
    October 25, 2007 at 2:25 am
    [HV20idiot] “even if the final video was 360×240 (or am I wrong about that?)”
    You mean 320 X 240
    And bigger images that use less information than the DV codec… are just bigger images that look terrible…
    HDV and Keying DO NOT go well together
    HDV in some cases, like Sony’s XDCAM and JVC Pro HD can work well for some scenarios… but I stay away from it in Motion graphics
  • Tim Kolb
    October 25, 2007 at 3:11 pm
    Well…I guess I’ll be the outcast here and say that while HDV may not be the pinnacle of greenscreen acquistion, it certainly keys better than NTSC DV if only because of the 4X pixel count and the 2×2 (4:2:0) color difference subsample block vs. NTSC DV’s 4×1…(4:1:1).
    While I’d never approach say, a national spot with an HDV key…I’ve certainly keyed competently shot HDV greenscreen footage and it’s no worse than dealing with HVX footage…
    I would key it in an HD comp, but choose a non-square pixel 1440×1080 comp and then what I would do is render it out at full res composited and allow myself some pan and scan in the final project.
    If the edges get messy, the best tip I ever got on keying DV was from Rick Gerard, a one-time AE forum host here at the Cow…it helps HDV as well, though typically the issue it resolves isn’t nearly as obvious in HDV anyway.
    Take your key clip and put it into a composition. Place it in the composition twice-exactly on “top” of itself. Take the top layer and apply a small blur (gaussian, fast, whatever you like) of about 2 pixels (adjust to taste). Then set the top layer’s blend mode to “color”. The top layer will smooth out a lot of edge artifacts, and will also help with general color noise present in the more compressed formats. Use this composition (you’ll see it in your project panel) as a clip in a new composition where you key it over the background.
    Good luck with it, and yes, starting with a higher res original image will help the final product look better, but follow any tips for compressing to YouTube standards that you can as avoiding recompression of non-compliant material will be the key to getting it to look like you intend.
    TimK,
    Director, Consultant
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Alan Tailer
    October 31, 2007 at 2:19 am
    I appreciate everyone’s responses, this board has been VERY helpful. I just purchased an HDV camera, and got so frustrated I was almost on the verge of returning it. (Frustrated trying to figure out the camera AND software AND how they work together, etc) After struggling through a lot of things, I can see it’s going to work well for me, and I thank everyone for their feedback!
