Activity › Forums › Apple Final Cut Pro Legacy › HDV footage with audio out of sync – 10 hours captured incorrectly!?
  • HDV footage with audio out of sync – 10 hours captured incorrectly!?
    Posted by Lisa Rolley on July 5, 2008 at 10:50 pm
    Hey friends happy 4th,
    I just imported all of this HDV 1080i 50 PAL footage – i did it from the camera we shot with (Sony HVR Z1‏) The entire footage 10 tapes is out of sync by about 3 or 4 frames. I am wondering if there is anything in the FCP playback settings, or anything whatsoever w/in FCP that could explain this.
    My fear is that it’s bc I didn’t use a deck and the camera was somehow worn out or whatever – but then it’s still weird that ALL 10 tapes come in out of sync. I’ve had it happen that a couple come in wrong but not all, and not all by the same amount – that’s why I’m hoping it’s something in the computer that’s fixable.
    any thoughts, clues, ideas?
    I plugged the camera into a tv and checked the sync there and it’s not out of sync there. I asked a friend and he said that sometimes depending on your playback settings, you could have it on a different frame rate than what you brought in and that will play it out of sync. I also tried making a 10 second quicktime of the footage from the timeline that looks out of sync and the quicktime is also out of sync.
    I need some serious help here – do we need to rent a deck and reimport or is it a FCP setting i have wrong??
    please someone help!
    Lisa
    David Roth weiss replied 18 years, 3 months ago 2 Members · 1 Reply
  • David Roth weiss
    July 6, 2008 at 4:33 am
    Lisa,
    Open File — System Settings — Playback Control and change the frame offset from 4 to 0. That should fix your problem. Apple for some reason has that setting defaulted to 4 when it should be zero. Who knows why???
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
