Activity Forums Apple Final Cut Pro Legacy HDV footage forcing me to re-render anything above v3 on HDV sequence…ideas?
  • HDV footage forcing me to re-render anything above v3 on HDV sequence…ideas?
    Posted by Gnwanya on December 7, 2006 at 12:28 pm
    Hi guys
    I have 1440×1080 HDV footage captured, and im editing natively on a HDV1440x1080 sequence. I have serveral footages stacked on top of each other but it seems that if i stack footage above v3, i am forced re-render anything about v3. This means i cant acutally cut the footages and see the edit in realtime without having to re-render. Would a multiclip be a good work around? (However Im still not quite comforable using multiclips).
    Any advice is appreciated.
    Gus
    G5 1.8 dual. / 3.5GB / FCP5
    Gnwanya replied 19 years, 9 months ago 2 Members · 2 Replies
  • Walter Biscardi
    December 7, 2006 at 12:38 pm
    Your system is not fast enough to support 4 layers of HDV material.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Gnwanya
    December 7, 2006 at 2:41 pm
    As I suspected. I will approach it from a multiclip alternative and go from there.
    Thanks for the response.
    Gus.
