  • Posted by Ross Hammond on May 11, 2006 at 11:26 am
    Someone has given me a sony HDVZ1 camera and a mixture of HDV and DV footage. I do have a sony DV deck with sdi out as well. I have lots of keying to do also. Could anyone give me some advice on capture and project settings, as I am thinking I have to take everything in as a Native DV project (SD). Therefore downconverting the HDV footage on the camera output.
    Jerry Hofmann replied 20 years, 4 months ago 4 Members · 4 Replies
  • Mike Johnson
    May 11, 2006 at 11:28 am
    I would capture everything native over firewire then downconvert.
  • Walter Biscardi
    May 11, 2006 at 11:31 am
    [chossy] “as I am thinking I have to take everything in as a Native DV project (SD). Therefore downconverting the HDV footage on the camera output”
    That’s probably the best way to go if you’re going to end up with an SD final project. Much easier to work with the footage if you bring it all in at the same codec / resolution during capture than dealing with it after it’s already in the system. That will set you up for a lot of extra rendering time that you really don’t need to do.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Ross Hammond
    May 11, 2006 at 1:07 pm
    Thanks for the help guys 🙂
  • Jerry Hofmann
    May 11, 2006 at 1:09 pm
    do the keying in Motion…. better chroma keyer there called the primatte keyer…
    Jerry
