  • Posted by Nikhil on February 6, 2007 at 12:59 pm
    HI
    we are facing problem with FCP using the setup of HDV 1080i 50 FireWire Basic, with this setup we can able to capture the footage via fire wirw from
    sony HDV recorder.but we are not able to give the out put with any of the HD setup from FCP,with same recorder with fire wire please suggest solution for this
    Regards,
    Rahul Commerce
    Support Engg.
    Nikhil & Sanjay
    Mark Maness replied 19 years, 6 months ago 2 Members · 1 Reply
  • Mark Maness
    February 6, 2007 at 2:44 pm
    You can only output HDV using your HDV 1080i50 Firewire Basic Easy Setup, unless you have a capture card.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
