Activity Forums Apple Final Cut Pro Legacy HDV digitizing Non-Drop/Drop issue BIG PROBLEM
  • HDV digitizing Non-Drop/Drop issue BIG PROBLEM
    Posted by Steven Koeppen on December 29, 2007 at 12:19 am
    Here is the issue: I have a project that has been logged in HDV via firewire. I’m now trying to digitize the HDV footage. I’m getting a error that says “Unable to locate timecode” Looking at the clips in the browser I can see that they are Non-Drop frame because there is a colon in between the second & frames but, when the capture window is opened when I batch capture, the timecode in the upper right corner above the video screen has a semi-colon. I’m not sure what to do or what to look for or what might have accidently changed.
    Any suggestions?
    Steven
    MacPro 2x 3GHz Quad-Core 8GB RAM 500GB HD
    FCS 2
    Sony HVR-M25U Deck
    Ben Avechuco replied 18 years, 9 months ago 4 Members · 3 Replies
  • Michael Palmer
    December 29, 2007 at 2:41 am
    What FC version are you running? Has the deck been used for any DV capturing between this project, if so make sure the setting are correct to output HDV over firewire and in doing so the firewire cable needs to be disconnected before any changes will take effect.
    Have you tried capture now and what is the timecode captured as this way?
    Good Luck
    Michael Palmer
  • Mark Raudonis
    December 29, 2007 at 4:01 am
    Steven,
    I think you may be confused… a “semicolon” indicates Drop, not “nondrop”.
    Mark
  • Ben Avechuco
    December 30, 2007 at 7:57 am
    I’m having the same problem as am searching for information here on the cow.
    2 days ago I brought in my drop-frame footage via firewire and now I want to recapture using HDV from my Z1U. When I select the clip and see the duration of the clip is 47;30;00 in length then try to batch digitize the clip again, it things the new clip is over 48:00:00 in length.
    I’m going to manually redigitize using the settings I had on the SD version of the clips and reconnect them manually as well.
    – Ben
