Activity Forums Apple Final Cut Pro Legacy HDV digitise into DVCProHD Codec
  • HDV digitise into DVCProHD Codec
    Posted by Paul Ingvarsson on June 22, 2007 at 4:12 pm
    Sorry for the dumb question – i’m not in front of a system right now so I can’t test for myself…
    It’s been suggested to me that you can can capture HDV firewire in FCP into the DVCProHD codec. (i.e. on a system that doesn’t have an HD card)
    I’m under the impression that this isn’t possible – can someone confirm this?
    Paul
    Rich Rubasch replied 19 years, 3 months ago 4 Members · 4 Replies
  • David Roth weiss
    June 22, 2007 at 4:32 pm
    Correct, its not possible. It does in fact require a capture card.
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Paul Ingvarsson
    June 22, 2007 at 4:36 pm
    Thanks David
    Paul
  • Andrew Kimery
    June 22, 2007 at 5:55 pm
    You don’t need a “full blown” card to do it though. If the camera/deck you are using has HDMI out you can get a BlackMagic Intensity card for a couple of hundred bucks.
    -A
  • Rich Rubasch
    June 23, 2007 at 3:23 am
    Or you can get a Convergent Designs M1 box that takes the HDMI and makes an HD SDI with embedded audio and takes the firewire and converts it to RS422 machine control. Works very well with our M25U deck.
    Rich Rubasch
    Tilt Media
