Activity Forums VEGAS Pro HDV Captures redundant frame
  • HDV Captures redundant frame
    Posted by Jim Kaye on February 18, 2009 at 9:45 pm
    I am using a Sony MiniDV HDV camcorder. I use my Vegas 8.0 to capture a series of shots, then move them to the timeline for editing. All takes have the last frame of the next take appended to the end. I presume this is due to the compression algorythm the camcorder uses. Anyway, I then need to remove the last frame or 2 from every take to avoid “glitches” in the edited output. When a lot of takes are involved it is a pain to do this manually.
    Is this problem unique to me? Is there a way to automate the process. I never had the issue editing in SD with SD source material on an older camcorder.
    Jim
    John Rofrano replied 17 years, 7 months ago 2 Members · 3 Replies
  • John Rofrano
    February 18, 2009 at 10:55 pm
    Unfortunately no, it is a known bug in the Vegas capture utility for HDV. You should turn off scene detection or use another utility to capture HDV.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Kaye
    February 19, 2009 at 5:42 pm
    Thanks, John, for the “reassurance” Any recommendation on what capture programs(s) to use for HDV? I used to use Scenalyzer with great success, but understand it won’t handle HDV.
    Jim
  • John Rofrano
    February 20, 2009 at 1:59 am
    Sorry I don’t use anything else. I just turned off scene detection and live with it. Some people like HDVSplit. I have never tried it.
    ~jr
