Activity Forums Apple Final Cut Pro Legacy HDV Capture Broken Up
  • HDV Capture Broken Up
    Posted by Eric Bridenstine on August 7, 2008 at 3:00 pm
    I am capturing 1080i60 off my Sony HDV camera and when I do a capture now, it breaks the clip up into 50 different segments and is constantly searching for media during the capture. It only captures around 2 minutes of the actual clip. My easy setup is HD and then HDV 1080i60 FireWire Basic. I am running 6.0.4
    Can anyone help?
    Eric
    Michael Craven replied 18 years ago 4 Members · 5 Replies
  • Kevin Monahan
    August 7, 2008 at 5:21 pm
    FireWire Basic is for Canon. Try regular FireWire for device control.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Eric Bridenstine
    August 7, 2008 at 6:16 pm
    I tried that as well, but it still searches for media during the capture. There are no timecode breaks and the clip was continuous with no starts or stops on the record.
  • Nate Martin
    August 8, 2008 at 11:15 pm
    Is Start/Stop detection turned off? If so, it sounds like a bad tape.
  • Nate Martin
    August 8, 2008 at 11:16 pm
    This isn’t always true, some Sony decks need to use Firewire Basic.
  • Michael Craven
    August 10, 2008 at 3:32 am
    I’ve encountered the same problem. I don’t know why it happens, but I tried capturing with a deck and had no problems whatsoever. The problem seems to be capturing via the camera.
