Activity Forums Apple Final Cut Pro Legacy HDV capture as DV PAL in Final Cut 6?
  • HDV capture as DV PAL in Final Cut 6?
    Posted by John Watts on February 10, 2009 at 10:55 am
    Hi
    I have some HDV footage that I want to capture as DV PAL, but Final Cut doesn’t seem to want me to do it. Is this something that is possible, or do I have to capture as HDV then use media manager to convert it to DV?
    Thanks in advance
    John
    John Watts replied 17 years, 6 months ago 2 Members · 2 Replies
  • Ben Holmes
    February 10, 2009 at 12:08 pm
    Most HDV cameras and decks have the option to downconvert the HDV signal to DV, so you can capture using the DV codec. If this is an option for you, this may be the simplest option.
    Hope that helps – I realise it’s not exactly what you’re asking.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • John Watts
    February 10, 2009 at 1:15 pm
    Thanks, I did actually manage to figure that out eventually, but thank you for responding!
    John
