  • Posted by Cecil Glenn on March 28, 2008 at 8:27 am
    I am in the process of cutting a television commercial. Some of the footage was shot in HDV. I captured the footage using the HDV1080i60 codec. Everything went fine. When I changed the settings bac to DV NTSC the footage is distorted. How do I get the clips to work right?
    Tom Dewitt replied 18 years, 5 months ago 2 Members · 1 Reply
  • Tom Dewitt
    March 28, 2008 at 3:26 pm
    Are you cutting a 16:9 commercial or 4:3? The HDV footage is 16:9 and if you are trying to make it into 16:9 DV NTSC you need to use a DV NTSC anamorphic sequence to maintain the aspect ratio. Or just crop the edges of the HDV footage in a 4:3 DV NTSC sequence.
