Activity Forums Apple Final Cut Pro Legacy HDV and DV in a HDV sequence, fields dominance.
  • HDV and DV in a HDV sequence, fields dominance.
    Posted by Crazy Cow on January 21, 2008 at 3:10 pm
    Hi
    I am mixing DV with HDV in an HDV timeline, PAL world. The final output will be a HDV master on tape. Because the DV material has to be resized and HDV-1080 PAL is upper field first, whereas DV PAL is lower field, I wonder whether I should de-interlace the DV material or process it in any other way to prevent having field issues, or this is something FC6 will take care of in the background ?
    Because unfortunately I can’t monitor at the moment with a video monitor, I only have the computer monitor, I can’t really spot problems visually.
    If someone has done this before and can give us a hand it would be very much appreciated, thanks in advance
    Crazy Cow replied 18 years, 8 months ago 3 Members · 3 Replies
  • Adam Taylor
    January 21, 2008 at 3:39 pm
    I wouldn’t deinterlace – that will remove data, use the Shift Fields filter ( i can’t remember exactly where it is) but it will let you swap the field order (and i’d do that on the dv material only)
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • Andy Mees
    January 21, 2008 at 3:49 pm
    Don’t worry, FCP will look after it for you … it will automatically add the Shift Fields filter for you when you add the DV clips to the HDV timeline.
    Do check it on a monitor before you commit back to tape tho’. You can use FCP6 to do a live DV downconvert of your HDV timeline, that way you can have a look on a typical standard def monitor or TV.
    If you have a high enough resolution computer monitor you can also resize your canvas to 100% … that way you can see the interlacing and maybe spot any problems.
  • Crazy Cow
    January 21, 2008 at 4:13 pm
    Thanks guys, that makes a lot of sense. I did notice that FC6 resizes automatically for you.
    I do at least have a PAL video monitor and will use the live downconvert.
    I love the cow, help comes fast
    thanks again
