Activity Forums VEGAS Pro HDV & 24P questions
  • HDV & 24P questions
    Posted by Enrique Orozco on June 5, 2006 at 7:06 pm
    OK… I’m going to begin tests with videos from a JVC-HD100 working with Vegas….
    1.- If I record 24P-DV… what do I need to do if I mix other DV-footage that is not 24P originally recorded?
    2.- If I record HDV… can I mix normal DV footage on my timeline with HDV files… will the final quality be different ?
    3.- Is the Cineform Connect HD software recomended for editing HDV ? (besides the codec included in Vegas…)
    EOR
    Jerry Waters replied 20 years, 3 months ago 3 Members · 2 Replies
  • Yoyodyne
    June 6, 2006 at 4:22 am
    —The quick and dirty option is to just dump it on your 24p timeline. The results can be pretty good actually. There are “better” ways to do it, convert your 60i footage to 24p, Magic Bullet and DVfilm come to mind right off the bat. I think there are some other tools as well…
    —I’ve had great luck mixing HDV and DV on a single timeline. Color correction can get a little funky because you are mixing color spaces but it’s not as bad as I feared. If your going to DV or mpeg-2 just make sure you are monitoring on an NTSC monitor.
    —I’ve been having great success with the JVC 24p and Cineform. It slurps in the footage no problem and the results look great, performance has been better than with 60i from the Z1. Easily worth the money.
    Hope this helps
  • Jerry Waters
    June 6, 2006 at 4:39 am
    HD Connect saves a lot of trouble.
