Activity Forums Adobe After Effects HDV 1440 x 1080 – What is proper Square Pixel Size
  • HDV 1440 x 1080 – What is proper Square Pixel Size
    Posted by Glenn Tak on February 18, 2008 at 9:43 pm
    OK – 720 x 540 Square is squeezed to 720 x 486 for D1
    What pixel ratio do I need to work with in Photoshop (Square) so that it comes into Final Cut Pro properly? My HDV footage is 1440 x 1080.
    I have calculated 1600 x 1080 and then squeezed it down but it still doesn’t look quite right.
    Thanks in advance
    TAK
    Beef! Its what’s for Dinner
    Steve Roberts replied 18 years, 6 months ago 2 Members · 3 Replies
  • Steve Roberts
    February 18, 2008 at 10:33 pm
    1920×1080. Why? Because that works out to 16×9, where 120 is the common factor.
    720×540 works out to 4×3. Like 640×480.
  • Glenn Tak
    February 18, 2008 at 10:43 pm
    I actually figured that out after posting the question.
    The thing that was confusing me is that with 4:3 you are squeezing the vertical number but with 16:9 you are squeezing the Horizontal.
    I’m sure as soon as I hit the post button I’ll figure out why but I would still appreciate your insight.
    Thanks for the quick response.
    TAK
  • Steve Roberts
    February 19, 2008 at 1:22 pm
    They’re two different specs — there’s no need for them to match. 🙂
    By the way, PAL is squeezed differently too. Off we go, merrily into the land of confusing video specs…
