Activity Forums Apple Final Cut Pro Legacy hdv 1280×720 video playback
  • hdv 1280×720 video playback
    Posted by Jonathan Hudson on March 6, 2008 at 10:16 pm
    i am unable to use external video when my easy setup is set to hd, hdv-720p24. when i go to Audio/Video Settings > A/V Devices and click on the video pulldown menu the option for HDV
    (1280 x 720) 24p is grayed out. Although i am able to select it in the “Different Output for Edit to Tape/ Print to Video area in the A/V Devices tab. What i am trying to do is playback my hd sequence to an hd monitor through my JVC BR-HD50 deck. I am using final cut pro 6.
    jon
    Chris Poisson replied 18 years, 6 months ago 3 Members · 2 Replies
  • Zane Barker
    March 6, 2008 at 11:30 pm
    That is PERFECTLY NORMAL, HDV is NOT like DV footage. You cannot just play it out firewire like DV video.
    No offense but you really should study up of a video format before you start editing with it.
    Don’t let technology get in the way of your creativity!
  • Chris Poisson
    March 8, 2008 at 8:31 pm
    Jonathan,
    You can play out to an Apple Cinema display via DVI, by selecting ACD full screen from your view>video playback menu.
    Or you can do the same thing with a Martox MXO only color calibrated.
    Only other option is to get some kind of HD card such as a Kona or BlackMagic.
    Have a wonderful day.
