Activity › Forums › Boris FX Particle Illusion › HDTV
Posted by Lsddigital on March 12, 2007 at 4:18 pm
Hi!
Can I export any animation to HDTV size? 1280×720 px
ThanksAlan Lorence replied 19 years, 6 months ago 2 Members · 1 Reply -
1 Reply
Alan Lorence
March 13, 2007 at 12:14 amYes with particleIllusion 3.0. You have to set your project up for that resolution at the start by setting the stage size to 1280 x 720. Then, you have to make sure that you make the stage window itself big enough to fit 1280 x 720 (since pIllusion needs a visible window to render into). If you can’t get a stage window large enough, you’ll have to work zoomed out, then do your final render using pIllusionRender.
Alan.
