Activity Forums Cinematography HDSDI monitor for 7D 5D
  • HDSDI monitor for 7D 5D
    Posted by Tim Sorel on January 24, 2011 at 10:11 pm
    Hello
    I am getting ready to shoot a short feature with the 7D. I have a great deal of HD gear including 17″ and 9″ Panasonic HDSDI monitors. I am going to try to use an AJA HDMI to HDSDI converter to feed a monitor for the director and camera operator.
    https://www.bhphotovideo.com/c/product/555772-REG/AJA_HA5_HA5_HDMI_to_SD_HD_SDI.html
    Has anyone tried this or know of why this may not work? I understand the cameras go into SD when recording. Other than that I do not have that much experience with this type of set up.
    Tim Sorel
    Gainesville, FL
    Bob Cole replied 15 years, 5 months ago 3 Members · 2 Replies
  • Richard Cooper
    February 1, 2011 at 7:12 pm
    Hi Tim,
    This should fit your needs nicely. Keep in mind it needs a power supply but you probably noticed that. Nice thing is that it actually has 2 HD/SDI outs so you can simultaneously go out to 2 monitors. Very handy.
    Also… while the other cannons down-convert upon recording you will find the 7D does not. While it is not a “clean” 1080p signal it is a nice hi res version (Not sure the exact specs) that looks great on an external monitor.
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Bob Cole
    February 3, 2011 at 4:22 pm
    [Richard Cooper] “while the other cannons down-convert upon recording you will find the 7D does not.”
    Do all the other Canon DSLRs down-convert the external video signal on recording? What about the 60d?
